Order Ford NAA Parts Online
NAA water pump pulley
Bob Stanley
01-10-2005 12:05:30
I'm in the process of rebuilding a Jubilee/NAA
and have hit another snag. The Generator and
engine pulley are wide while the water pump pulley is narrow. I suspect the wide pulleys are
correct. My Ford/New Holland dealer claims that
the item is no longer serviced. First which pulley(s) are correct and do any of you guys have
correct pulley(s) you would part with. Thanks,
Bob Stanley
Scott PA
01-10-2005 17:26:02
 Re: NAA water pump pulley in reply to Bob Stanley, 01-10-2005 12:05:30
The 1953-1954 NAA (Jubilee) use a unique water pump (CDPN8501B) because of the wide width of the pressed on pulley that only comes w/ the pump, maybe someone has a old pump to send you so you can switch pulleys.
Bob Stanley
01-11-2005 13:56:51
 Re: NAA water pump pulley in reply to Scott PA, 01-10-2005 17:26:02
Thanks, I reposted under another topic and will
buy a new pump. I think my NAA has a 100 series
pump, pulley and extension. The pump and related items will not go to waste as I also have an 850
and a 961 that the stuff currently on the NAA will fit. Live and learn, Thanks for your help.
Bob Stanley
