Order Ford 5000 Parts Online
ford 5000 clutch problems
BoxMan
01-12-2005 09:29:11
I have a gas ford 5000 and the clutch appears to be going bad. Clutch as been slowly getting worse over time. Transmission will go into High side and low side after warming up. Gear shifter is in #2 position and will not move out of that position with Clutch fully engaged. Is there anyway to adjust it. If it can"t be adjusted, I would appreciate detailed information on how to replace it.
Thanks.
