3 point lift problems
Mark in PA
05-21-2001 09:20:52
Just bought a 1958 641 tractor so far the only problem i found is the 3 point lift arms only raise about half way.they don't raise at all when the draft/position control lever is in the draft position.when the lever is in the position control they raise half way and seem to have plenty of power(picks up 5 ft bush hog no problem).any ideas on the solution to my problem greatly appreciated!
albe
05-21-2001 10:21:44
 Re: 3 point lift problems in reply to Mark in PA, 05-21-2001 09:20:52
I had the same problem with my 621. I replaced the lift "pin"( it was worn about in half) and since I had it apart, all of the "o" rings including the piston "O" ring. Works great now. Zane offers the "pin" with great instructions and a gage for about $40. The 'O" ring kit and gasket for the lift cover was about $10.00 at the local New Holland dealer. Worked for me! albe
