Head Ford 1210
Bob Trower
01-16-2005 12:18:23
I recently bought a Ford 1210 that did not run and found the head was cracked. I bought a used head from a tractor supply in Alabama that pressure tested to be good. I had the head magnafluxed and found that it had a small surface crack in the same location my head was cracked into the water jacket. The machine shop recommended that I take the heads to R.E.V. Head Service in Kingdom City, MO and have them repaired. I had both heads repaired and have run the original head, which was cracked badly, for 20 hours with no problem.
The head I bought was on a Shibrua tractor and will bolt up to the 1210 engine however the fuel injectors are different. The head casting number is N831. According to a factory parts list, there were 3 head castings for this engine that were used on several models of Ford & Shibrua tractors.
Can anyone tell me what tractors the N831 head was used on or where to find that info?
BigDiesel
01-19-2005 05:07:41
 Re: Head Ford 1210 in reply to Bob Trower, 01-16-2005 12:18:23
I think I have a real good head for you, mine is a 3 cylinder..... tom
crazy02917
10-25-2005 09:33:21
 Re: Head Ford 1210 in reply to BigDiesel, 01-19-2005 05:07:41
I am looking for a 1210 head with casting number N832. Thanks, Mike
9n141
01-16-2005 17:08:09
www.fawcett.cc These are an excellent salvage yard , they have a 1210 wrecked. I have no connection to this co. but have done exstensive business with them. BURT
