Order Ford 5000 Parts Online
Ford 5000 serial #s
Boxman
01-17-2005 11:01:15
I have several serial #s stamped on tractor.
(c374068) is just one of four or more. Can someone tell me if this is the correct one.
And if it is what it represents.
I have a clutch problem and most likely will need parts, so any information would be of help.
Thanks.
Pernell
01-17-2005 21:27:19
 Re: Ford 5000 serial #s in reply to Boxman, 01-17-2005 11:01:15
Your 5000 is a 1973 model, clutch pedal free travel should be about 1,1/2". A rebuilt unit with the bearings should cost you about $350.00, maybe a little less if you shop around.
Jim.UT
01-17-2005 14:51:32
Here's a site where you may find the info you need.
Boxman
01-17-2005 16:06:03
 Re: Ford 5000 serial #s in reply to Jim.UT, 01-17-2005 14:51:32
Thanks for your help I will check it out.
Do you know anyhting about clutch adjustment or replacement.
Jim.UT
01-17-2005 19:21:40
 Re: Ford 5000 serial #s in reply to Boxman, 01-17-2005 16:06:03
Sorry, I don't. Someone here will, though.
Boxman
01-18-2005 11:58:04
 Re: Ford 5000 serial #s in reply to Jim.UT, 01-17-2005 19:21:40
Again, Thank you. I tried the web site you mentioned and I beleive I have the info. I needed.
Have a good one.
