Order Ford NAA Parts Online
jubilee pinion shaft
BigGeorge
01-20-2005 16:43:55
I removed the differential pinion shaft in order to replace the pitted bearings. The I&T shop manual shows a snap ring that holds the pinion pilot bearing on the shaft but on mine there is no such snap ring or even a groove in the shaft for a snap ring. The bearing was a snug fit on the shaft but not a press fit. My concern is that the bearing could walk off the shaft. Also the manual says that after serial naa44482 (mine is naa 50758) that the ring and pinion both should be marked with the numbers "25PA" neither has this marking. I suspect someone down the line may have changed both because the ring gear is bolted not rivited onto the differential case. Anyone else run into this? Your response is appreciated.
