Steering gear housing leaks -Grease?
Bobrh
01-30-2005 20:07:33
I've seen posts being negative on using greaes to stop the leaks. Ford recommended using grease in 1962- did they later change that recommendation?
txblu
01-31-2005 06:02:13
 Re: Steering gear housing leaks -Grease? in reply to Bobrh, 01-30-2005 20:07:33
Dunno, but I have 62, 64, 65, and 74 Fords. If one leaks, I put in Lubriplate #105 grease. End of problem. 105 is thicker than 140 wt gear oil but thinner than regular "grease gun" grease. It's thick enough to stay put, but thin enough to flow to do it's thing.
Mark
Bobrh
01-31-2005 07:11:41
 Re: Steering gear housing leaks -Grease? in reply to txblu, 01-31-2005 06:02:13
Sounds like your doing what Ford recomended which was using grade "0" grease which is lighter than grade 1. I found that info in a service bulletin from Ford in 1962.
txblu
02-01-2005 06:53:01
 Re: Steering gear housing leaks -Grease? in reply to Bobrh, 01-31-2005 07:11:41
I dunno. Not familiar with the Ford grease specs.
Mark
Tom in TN
01-31-2005 06:28:56
Hey txblu,
My steering box leaks slightly. I'd like to try the #105 Lubriplate. Where do you acquire it? Auto parts store?
Thanks for any help.
Tom in TN
txblu
02-01-2005 06:51:46
 Re: Steering gear housing leaks -Grease? in reply to Tom in TN, 01-31-2005 06:28:56
It's at auto stores. Marketed in a white tube with blue cap and red writing. Says "engine rebuilding grease" on the tube as that is what it's made for but it is perfect for old gear boxes including your shredder.
Mark
