Order Ford 2000 Parts Online
Sediment bowl for 3000 and 2000
Art in Tex
02-03-2005 06:02:05
Need replacement glass bowls for both of these early 70's tractors which have the same size bowl. Its a smaller mouth bowl than the ones that I've come across so far. Is there a source for these or a replacement for the whole device?
Thanks for any help.
Charles (in GA)
02-03-2005 10:36:20
 Re: Sediment bowl for 3000 and 2000 in reply to Art in Tex, 02-03-2005 06:02:05
I recently bought a brass bowl from the NH dealer. It was shorter than the existing glass jar that was on it (threaded har no less, but the old time NH parts man speculated it was original) Instead of installing a shorter bail (never gave that any thought), I took a 1/4-28 bolt and cut off the head, slit it with a abrasive wheel and installed it in the place of the existing threaded stud and crimped it on the bail. Looks original, works fine, cheap.
Charles
Pernell
02-03-2005 07:22:26
The new bowls are machined out of brass and longer than the older short square ones so you will have to replace the bail also! Bowl part# 86508531 $7.47, bail part# D4NN9C297A $13.82
