oil blowing out of exhaust on 172 red tiger engine
alcid
02-08-2005 18:46:46
oil blowing out of exhaust, not just smoke.pulled pistons looking for bad oil rings. unable to determine if any bad.gauge shows good oil preasure. While apart going to run hone through cylinders and install new rings and bearings.any ideas?
BigGeorge
02-08-2005 22:21:50
 Re: oil blowing out of exhaust on 172 red tiger en in reply to alcid, 02-08-2005 18:46:46
I agree with Ford Power, also check the oil return holes to make sure they are not plugged with gunk, This will keep oil from returning to the pan fast enough. Oil will stay up in the valve cover and get sucked past the valve guides.
ford power
02-08-2005 18:56:49
send out your cylender head to be checked magnafluxed for cracks and NEW INTAKE AND EXHAUST VALVES AND GUIDES that is where most oil comes from when coming out the exhaust, you will find your exhaust valves very worn, good luck on your overhaul
