SOS lube sender Hobbs
Bobrh
02-10-2005 12:50:22
As discussed there is a replacement Hobbs sender still made by Stewart Warner at their Hobbs factory. It is pressure switch Stewart Warner number 78149. Sam said he used the Napa 701-1605 NC. I went to NAPA a found these are the same identical Hobbs switches. Napa here said it was $52.00 If you need more than one find a Stewart Warner dealer as I bought 4 for $120 from a local shop last year. Again they are identical and are the 2psi normally closed switch that matches the original spec and mine works great.
