Order Ford 3000 Parts Online
Ford 3000 PTO pump
Beststash
02-12-2005 13:53:56
Has anyone ever used a PTO hydraulic pump for a loader with built-in reservoir?? What is the down-side??
Does anyone make a PTO extension that would allow the PTO to be used for shredder with pump mounted??
I have seen a Prince pump that appears to have a "thru" PTO shaft connection but I would guess that the original shaft would be too short for concurrent use??
Anyone with experience??
Thanks
Charles (in GA)
02-12-2005 19:15:19
 Re: Ford 3000 PTO pump in reply to Beststash, 02-12-2005 13:53:56
Tractor Supply has a 15 inch 1-3/8x6 spline shaft extension in their catalog. "extended length for use with the Gresen pump. Pump slides over the adapter."
p/n 02-71091 $56.64
Charles
Beststash
02-13-2005 11:00:51
 Re: Ford 3000 PTO pump in reply to Charles (in GA), 02-12-2005 19:15:19
Thanks Charles!!!
