Order Ford 600 Parts Online
600 hydraulic problem?
Bob Rice
02-21-2005 19:02:01
I have a 1956 ford 600 that runs great however the hydrulics dont seem to work correctley.I have to let the tractor run for appx 5 min with the touch controll in the up position before the hydraulics work.When they do they go up they seem to be jumpy on their way up and go down smoothly .Is this normal?
Kirt F.
02-22-2005 16:19:33
 Re: 600 hydraulic problem? in reply to Bob Rice, 02-21-2005 19:02:01
I have a 1955 640 that had the same symptoms. I had to bleed the air out of the hydraulic pump every time I used it. This can be done by loosening the hex head plug on top of the pump, the one at the front. I ended up re-building my pump, to include the seal that goes around the wobble plate shaft. This cured my problem. The re-build is straight forward and easy, the only exception being getting the wobble plate shaft seal. It too is not that hard once you know how it is done.
Pernell
02-21-2005 20:09:24
The seats are getting worn in your hydraulic pump and you are slowly losing your prime, you need to put a kit in it.
awhtx
02-21-2005 19:12:40
It sounds like someone put 90 wt. gear oil in the hydraulic compartment. Drain it out and replace it with hydraulic oil that meets FNH 134 specs.
