Getting started with a 4000
lots to learn!
Bill Oakes
06-02-2001 05:19:42
I just bought a real nice 1970 Ford 4000 (3 cyl). Many things different from my 681. I really need sway bars for the 3 point hitch; the NH dealer just shrugged his shoulders and said he coundn't help. Where can I get these? The rear axle setup is different from the 600/800 tractors. This NH dealer couldn't even give me a valve cover gasket. I would also like to put a snowplow on the front of the tractor and if I get really lucky I might even find a cab to keep the winter winds off of me. Any 4000 owners out there that might be able to help? Thanks, Bill
Sam
06-02-2001 06:17:41
 Re: Getting started with a 4000 - lots to learn! in reply to Bill Oakes, 06-02-2001 05:19:42
Hi Bill, Sounds like you need to find another FNH dealer that treat you as a customer. Book shows stabilizer kits available as CJPNN904A Kit, Stabilizer, Dual Cat., w/Rigid Link., and C7NNN869A Kit, Stabliizer, w/Flexible Links. I dont know what the difference is but they show for 4000 models from 1965 on.
RWK in WI
06-02-2001 15:54:05
 Re: Re: Getting started with a 4000 - lots to learn! in reply to Sam , 06-02-2001 06:17:41
Rigid link = lower three point arms are gitted with hitch balls solid to arms.
Flexable link = ball part of lower arm can be extended and or tilted to ease hook up then becomes rigid again.
MarkB
06-02-2001 06:12:38
I'd say the first thing you need to find is a different New Holland dealer. Not trying to be facetious; any dealer that can't even manage a valve cover gasket is either lazy, inconsiderate, or both.
You might want to post your location and see if anyone can recommend a different dealer in your area.
George H
06-02-2001 09:27:50
 Re: Re: Re: Getting started with a 4000 - lots to learn! in reply to New Holland dealers, 06-02-2001 08:58:41
hi Bill,
Stabilizer bars are available both rigid and adjustable. Adjustable types are threaded, and function exactly like a 3-point hitch top link. The 'flexible' kit that Sam described are probably 'adjustable'. They're used to offset an implement. A pair of rigid bars for older Fords costs under $20 at Tractor Supply, and a pair of adjustable bars are about $45 (mounting brackets extra).
It's common to use only one bar instead of a pair. but to me, it doesn't seem right to place all the stress on one side. regards, George
