Order Ford 3400 Parts Online
1975 ford 3400 dash board
bill/va
03-10-2005 06:56:04
i am posting this for a friend he wants to know where and how much does it cost for a dash board (containing temperature guage, lights, proof meter etc.) thanks jubilee owner
Pernell
03-10-2005 09:23:48
 Re: 1975 ford 3400 dash board in reply to bill/va, 03-10-2005 06:56:04
I,ve got it for $174.08.
bill/va
03-10-2005 19:17:13
 Re: 1975 ford 3400 dash board in reply to Pernell, 03-10-2005 09:23:48
where did you get it????
Pernell
03-10-2005 19:30:10
 Re: 1975 ford 3400 dash board in reply to bill/va, 03-10-2005 19:17:13
I sell them new. I'm a New Holland parts man.
Bern
03-10-2005 20:58:39
 Re: 1975 ford 3400 dash board in reply to Pernell, 03-10-2005 19:30:10
Does that price include the updated sending units?
Rod F.
03-11-2005 06:25:08
 Re: 1975 ford 3400 dash board in reply to Bern, 03-10-2005 20:58:39
As far as I am aware, the sending units do not need to be changed. Only time I have changed the sending units is when I have switched to a newer generation cluster, which I did for tach purposes rather than parts availability on the old cluster. Take care.
Rod
Pernell
03-11-2005 04:31:09
This panel uses the ORIGINAL sending units.
Bern
03-11-2005 18:17:13
 Re: 1975 ford 3400 dash board in reply to Pernell, 03-11-2005 04:31:09
Is it from NH? Because if it is, last time I checked, they used the newer style magnetic gauges that required the newer sending units to go along with. Original sending units are for use with bi-metal gauges.
Pernell
03-11-2005 21:20:27
 Re: 1975 ford 3400 dash board in reply to Bern, 03-11-2005 18:17:13
Your right, the one from NH does require changing of the sending units and looks ugly in the older tractors, this one is from A & I Products and is as close as the original one that I have seen and uses original sending units, it even uses the voltage stabilizer on the back, only noticeable difference is it has place for 4 warning bulbs instead of 2 like the original.
