Order Ford 4000 Parts Online
Ford 4000 Diesel Problem
Barry Mattingly
06-02-2001 20:14:00
I have a 1974 Ford 4000 diesel. Earlier this year I was bushhogging with it and it started to miss. I have changed the fuel filer twice, both times it has had a lot of crud in it. I have changed injectors and it still misses. It starts good and idles good until it runs for a while and then the miss begins, I have noticed that when it is missing there is very little or no fuel coming from the return line into the fuel tank. Any suggestions would be helpful. Thanks
Jeremy Homan
11-01-2001 20:46:05
 Re: Ford 4000 Diesel Problem in reply to Barry Mattingly, 06-02-2001 20:14:00
Me and a friend of mine work on his race car a lot. One time it would idle fine but once you got on it hard it would cut out like it didnt have power. We put a new filter on it, tried a new carberator and it still did it. Turns out there was a hole in the gas line. Problem solved. We unhooked the fuel line up by the carburator and blew air into the line with a air compressor and looked for air leaks. this maybe your problem?? Just thought I would give you my thoughts.
RickB
06-03-2001 03:42:28
There is a screen on the shutoff valve at the tank outlet. This is probably plugged. Remove the line to the filter head, and check fuel flow out of the tank. If it is just a trickle, clean or replace the fuel shutoff.
ErnieD
06-04-2001 16:40:15
 Re: Re: Ford 4000 Diesel Problem in reply to RickB, 06-03-2001 03:42:28
Get fresh fuel.
ErnieD
06-04-2001 16:40:13
Get fresh fuel.
