Order Ford 4000 Parts Online
Ford 4000 serial #
Al
06-02-2001 21:34:48
This past weekend looked at a 63 Ford 4000 with p/s.I'm confused by the serial number stamped on the trans.by the starter.It's stamped 860 under that <>22422<>.Is there anywhere else i can look for a serial number.I'm thinking maybe the trans. was changed out ,because the rest of the tractor looks like a early 4000.Anybody have any thoughts.
Dan Robertson
06-03-2001 05:40:18
 Re: Ford 4000 serial # in reply to Al, 06-02-2001 21:34:48
If you are sure it is 4000 sheet metal,(the serial # could be from a 63-4000 or a 58-860), then it in all probability began life as a 4000 Select-O-speed. My guess is that at some point in time the SOS tranny has been replaced with the tranny from an earlier tractor. Are there any indications of a SOS shifter being mounted under the steering wheel, or a cable pto control on the right side just under the throttle control? Dan Robertson
rod
06-02-2001 22:09:08
How sure are you its a 4000?. Sounds more like a 58 800 series.
rod(follow up)
06-02-2001 22:13:01
 Re: Re: Ford 4000 serial # in reply to rod, 06-02-2001 22:09:08
Click on Production Codes..
Al
06-02-2001 22:52:58
 Re: Re: Re: Ford 4000 serial # in reply to rod(follow up), 06-02-2001 22:13:01
4000 Answer to Rod,It's being sold as a 63,4000.The sheet metal is 4000.
