Maybe a little OT
AZglide
03-19-2005 14:23:41
After almost getting run into the last time I was driving down the road I thought about rigging up a rear flashing light to maybe let the idiots around here know that I am not going 20 mph over the speed limit like every one else. (apparently the SMV emblem doesn't mean anything to them) Stopped by the local TSC today and picked up a flasher and light that I didn't think would look to out of place on the NAA but after trying diffrent wiring configurations still can't make it flash. Anyone out there know how to wire this puppy up so it will work? I got the cheapy two terminal flasher. As usual, thanks in advance for any information or comments you have.
RWK in WI
03-19-2005 17:17:59
 Re: Maybe a little OT in reply to AZglide, 03-19-2005 14:23:41
Most of the small / cheap flasher units are for a fixed number of bulbs ( 2 or 3 ) and won't work on a single bulb. A "variable load" flasher unit will work with anywhere from 1 to 6 bulbs. These cost more but are needed for what you want or for some trailer towing vehicles. I hope this helps you.
RickB
03-19-2005 17:02:23
Not many choices. I would wire it Battery/ Fuse/ Switch/ Flasher unit/ Lamp. If you are having difficulty, wire it on a temporary basis without the flasher to prove the rest of the circuit. Most common tractor lamps are frame grounded. You may not be getting a good ground between the fender and axle housing. 65.8% of fender mounted light troubles I encounter are fender related ground problems.
Larry NCKS
03-19-2005 14:34:06
Are you trying to put a 12 volt flasher on a 6 volt system?
AZglide
03-19-2005 16:56:15
 Re: Maybe a little OT in reply to Larry NCKS, 03-19-2005 14:34:06
no, tractor has been converted to 12v.
