Starting a ford 7000
Alan Mc
03-21-2005 22:36:00
I found a 1974 ford 7000. When I start it the red light on the dash won't go out unless I idle up around 1200 or so. Is this the oil pressure to thr turbo?
Tractor Dan
03-23-2005 16:00:46
 Re: Starting a ford 7000 in reply to Alan Mc, 03-21-2005 22:36:00
we had a 74 7000 and it had your oil pressure and generator light in the tach or cluster but i remember a red light outside of the cluster but for the life of me i dont remember what it was for
Hummy
03-22-2005 16:18:30
That light is for the air filter-It should go out. There is a sender for it under the dash.
gerard
03-22-2005 13:48:52
Turbo oil pressure is same as engine oil pressure. If your symptons were oil related, I'd suggest you'd have some knocking noises as well. Reckon other postings right - it's charging. Test by pulling small wire off dynamo / alt - light will go out if it's a charging warning light.
Rod F.
03-22-2005 07:21:20
The little red light on the left? That's the charge indicator light. Sounds like you still have the original generator in place. That is fairly normal practice for that light. When it stays on, then you have a problem. HTH.
Rod
Alan Mc
03-22-2005 10:09:23
 Re: Starting a ford 7000 in reply to Rod F., 03-22-2005 07:21:20
This red light is located out side of the gauge cluster to the lower right???? I have a charge light in the gauge cluster. I still think it has something to do with oil pressure.
Rod F.
03-22-2005 14:16:08
 Re: Starting a ford 7000 in reply to Alan Mc, 03-22-2005 10:09:23
I'm not familiar with any lights outside the cluster on thousand series tractors. I could only speculate on what it is. Mabey an add on? Could be an extra engine oil pressure light, or a hyd charge pressure sensor for the dual power/PTO circuit. those would be my best guesses. If it's a pressure light, then it is starting to sound dubious to me. Chase the wiring down and see where it goes, and what it might operate. HTH.
Rod
Alan Mc
03-23-2005 17:53:38
 Re: Starting a ford 7000 in reply to Rod F., 03-22-2005 14:16:08
I found it. If that light comes on it tells U that the air filter needs to be cleaned as per the ford service manual that I borrowed from a buddy that has a 7000.... One person who responded got it right. Thanks again. This is a new tractor to me. Alot that I don't know.
