Order Ford 4500 Parts Online
73 Ford 4500 TLB, Fluid Crossover List, Sheet Meta
4500 Jerry
03-22-2005 16:58:33
Greetings Folks,
I just purchased this 1973 Ford 4500 TLB and would like to drain the old fluids and replace with new. The problem is that the Operators Manual has old Ford Fluid numbers. Does anyone have a crossover list from these old numbers to todays Fluids or any recommendations of what to use? Here is the list;
Hydraulic Fluid ESE-M2C48-A M2C48-A
Steering Gear Housing ESEN-M2C94-A ESW-M2C28-BA M-4864-B
Transmission 6 Speed Forward 4 Reverse FSW-M2C77-A M-4864-A
Also here is my wish list;
1) 3 Point Lift Arms Pins that attach under the tractor
2) Sheet Metal on each side of cowling in front of radiator
3) Sheet Metal under Dash around steering shaft housing
4) Sheet metal on top of cowling that covers the Hydraulic filler
5) Parking brake “T” handle
6) Grill
7) The Ford Name plate on the front of cowling
Thanks for your time in this matter.
Sincerely,
Jerry
