Order Ford 2000 Parts Online
2000 No Rear Hydraulics
Pat
06-04-2001 20:20:10
I have a 1963 Ford 2000. The three point stopped working. It is in the lowest postion. I have tried engaging the draft control and nothing.
I have checked the fluid and checked the pump for prime, nothing. What next?
Mark H, Ont
06-05-2001 17:01:56
 Re: 2000 No Rear Hydraulics in reply to Pat, 06-04-2001 20:20:10
When you checked the pump for prime, you said nothing, meaning... no oil, or no air, or...?
There should have been oil seeping around the plug when you loosened it.
Any chance your proofmeter stopped working at the same time? On one rare occasion, I actually saw the splines on the pump shaft let go, that was a pricey fix....
TomG
06-05-2001 03:49:55
If no other hydraulics are present to verify that the pump produces pressure and the relief valve is OK, I'd do a pressure test.
