Order Ford 801 Parts Online
801 valve cover gasket
BradB
03-27-2005 13:00:03
I need to replace my valve cover gasket. Can I do it with out removing the hood and gas tank? Looks like it may be possible but I figured someone would know. Thanks
Feron
03-27-2005 17:48:30
 Re: 801 valve cover gasket in reply to BradB, 03-27-2005 13:00:03
Yes you can change the V C gasket with no problem. Without removing the hood and tank. Just make sure you get the surfaces clean.
old
03-27-2005 13:54:48
You might be able to do it that way but you probably couldn't clean up the head very well and would end up with a oil leak.
BradB
03-28-2005 14:42:11
 Re: 801 valve cover gasket in reply to old, 03-27-2005 13:54:48
Got an oil leak now so I will give it a try and see what happens. Thanks
