Order Ford 3000 Parts Online
Front tires Ford 3000
Asbjorn
03-29-2005 13:53:29
Hello
I have 12,4-32 rear tires and 7,50x16 in front.
Have anyone tried 235/85-16 truck tires up front on a Ford 3000 ?
It looks like a close fit whit my stock tires and the truck tire is maybe wider?
Would have been nice if it fits, my brother have a suburban :)
TomTX
03-31-2005 03:10:50
 Re: Front tires Ford 3000 in reply to Asbjorn, 03-29-2005 13:53:29
What do you use the tractor for? If you work in soft ground, you will not like the steering with truck tires on it. Been there done that. The high ribs on tractor fronts are designed for proper steering control on plowed ground or soft ground.
txblu
03-30-2005 05:55:22
Reverse the wheels. Have one with P23575R15 XL's on it.
txblu
03-30-2005 05:56:59
 Re: Front tires Ford 3000 in reply to txblu, 03-30-2005 05:55:22
Wrong take-off. Was just thinking that the Ford uses 16" wheel. Try P245x75R16XL off my '98 Dodge P/U.
old
03-29-2005 19:18:48
I use truck tires on a lot of my tractors they last longer the tractor fronts in thorn country
