Order Ford 4400 Parts Online
FORD 4400 Hydralic Spoon Change
Bigwater
04-06-2005 00:03:01
Has any one change a 2 lever bad spool valve and replaced it with a single level joy stick with auto float? If so, how do you like it?
Roy Suomi
04-06-2005 19:47:10
 Re: FORD 4400 Hydralic Spoon Change in reply to Bigwater, 04-06-2005 00:03:01
Did it , works great. Bought a valve from Surplus Center. Look them up at surpluscenter.com Make sure you get a valve with large enough gallon per minute rating at the correct pressure rating
Bigwater
04-06-2005 23:54:50
 Re: FORD 4400 Hydralic Spoon Change in reply to Roy Suomi, 04-06-2005 19:47:10
I checked out surplus center and your right there's several valve sizes available. Looks like you need to by the joy stick assy and then the valve body. Did you have to change hyd. hoses-lines & replumb??
Thanks
Roy Suomi
04-10-2005 20:59:13
 Re: FORD 4400 Hydralic Spoon Change in reply to Bigwater, 04-06-2005 23:54:50
Got your E-Mail.....I bought a Cessna open center valve [ 2 spool ] 20 gallon per minute valve. Don't remember exactly which valve it was. I used loader linkage from a J.D. 301 loader tractor with a little modification..I had to shorten the handle a little too..
