Rod F.
04-08-2005 19:03:09
Re: 3 point lift of 4000 Ford in reply to Art Maggio, 04-08-2005 18:42:46
Hi Art, The position control lever is the large one, and you use that to set the height of the arms. The small lever is the system selector, which allows you to select between draft and position control. In draft, the height of the arms is controlled by a spring, which recieves it's tension signal from the upper link (top link). Basically, in draft, your control is limited to up or down. That's why you have a system selector that allows position control, so that you can set the height of the arms for most jobs other than moldboard plowing. From what you have described so far, it sounds to me as if the control valve is sticking. This is simply the valve that those levers act on. It is also spring loaded, so you don't really notice much difference in feel, just that nothing moves when it is supposed to. This problem could be related to dirty oil/particulate in the valve or just seized in the bore. My best advice for you is to get a Ford/NewHolland sevrice manual for your model/year, and study the hydraulic lift cover setting procedures. You will have to pull the lift cover, and either free up/clean the valve or possibly replace the valve. Cleaning often works. The other option is to pull the cover off, and go to a NH dealer and have them set the cover up for you. There's nothing special about taking the cover off, but setting is a rather special procedure, that calls for some special tools. You can do without the tools, but it's imperative to understand the concept behind it first, so that you can improvise with a depth gauge. HTH.Rod
