Order Ford 601 Parts Online
601 HYDRAULIC PROB.. HELP!!!
bobcat
04-08-2005 10:29:36
I changed the hydraulic oil in my 601. Now the lift shakes up and down . I put hydraulic oil from the parts store in it. Is it possible there a special oil?
Larry NCKS
04-09-2005 14:41:55
 Re: 601 HYDRAULIC PROB.. HELP!!! in reply to bobcat, 04-08-2005 10:29:36
bleed the air and you'll be fine, as long as the oil you put in meets or exceeds the Ford 134 specs.
John in OH
04-09-2005 03:38:07
It sounds like it has air in the system. Did you bleed the system? You really should use 134 Ford oil also, but There are other oils that are compatible.
Dan
04-08-2005 13:47:51
Does the oil you bought say it is 134D compatable? If so, it is fine. Most likely you have a sticking valve in your lift cover.
Dan
