Order Ford 600 Parts Online
Ford 600
Alex Lemieux
06-08-2001 12:06:03
I acquired a ford 600 with some land that I bought near San Diego. It has a front loader, land plane, plow, and misc. other implements. It hasn't been run in several years, but I think it shouldn't be too big a deal to get it running. Anyone have any idea of what the value of the package is?
I have no use for the tractor, and would like to sell it.
rick/mi
06-11-2001 08:10:52
 Re: Ford 600 in reply to Alex Lemieux, 06-08-2001 12:06:03
what's a land plane???
Alex Lemieux
06-11-2001 15:40:09
 Re: Re: Ford 600 in reply to rick/mi, 06-11-2001 08:10:52
a land plane is a device used to level land in areas where flood irrigation is used. The object is to have the land very flat in one direction with a slight grade in the other direction so you can open the irrigation ditch and it will cover the whole field.
Kirkules
06-11-2001 14:44:01
Well, you know...an airplane flies through the air so a land plane...
Jon,NH
06-10-2001 03:50:52
A Ford 600 Tractor w/loader,in a not running conditon,will bring where i live at least $1200 with no added equipment,with the equipment more,what other options does this tractor have?power steering?sherman trans?remote hyds for the access plate?drawbar?all these things add to the value.If you were within easy traveling distance for me,i would love to look at it,though a picture would do.
Jim.UT
06-09-2001 14:34:23
George's comments seem about right to me. You could always sell the implements separately for a hundred or three each, depending on how big a sucker you have on the hook. To learn more about the 600 and to positively identify which model of the several that were offered in the 600 series click here.
George H
06-08-2001 23:26:51
$2000 as is, $5000 if it's running and the loader works. If it's beat up, then less all the way down to 'not interested'.
