Order Ford 801 Parts Online
Ford 801 Powermaster diesel
AL F.
04-16-2005 20:22:15
I just purchased a Ford Tractor. The emblem on both sides read 801 Powermaster. I can not make out the serial number on the flat spot behind starter. Is there any other way to tell what year it was made. I found on a metal plate on left side of engine 4084S8KC. This same plate reads Industrial and COOB-6006-G. Other information. It has diesel engine, power steering, The emblem on front has a lightening bolt, red trans and engine, pto, 12 volt system.
Al F
04-17-2005 08:47:29
 Re: Ford 801 Powermaster diesel in reply to AL F., 04-16-2005 20:22:15
The numbers on the rear axle are
left side NDA 4013C
right side NDA 4012C and 1918
Why do you think this is not original engine?
Thanks
awhtx
04-17-2005 05:28:41
The serial number on most of the 801 diesels has been eaten away by battery acid. Look on the rear axle trumpets for casting dates.
It sounds like your original engine has been replaced.
