Order Ford 801 Parts Online
Air intake question Ford 801 diesel
Al F
04-22-2005 08:04:40
Need to replace the air intake breather housing. The nut on bolt are rusted together and just turn when try to remove. Does the housing screw off the intake pipe or is it all one peice?
john in la
04-22-2005 18:16:56
 Re: Air intake question Ford 801 diesel in reply to Al F, 04-22-2005 08:04:40
OK lets see if I can answer a couple of questions you asked me but that I never got around to answering.
What air filter do you have and what nut/bolt are you talking about.
third party image
third party image
The pictures may answer your question.
Now you wanted to know how to post a picture. First find the picture you want to post on your computer. Now go to this web site. Image Upload Site
Follow the instructions to upload your picture to the internet. Once you have uploaded your picture it will give you a web address to your picture in red. Copy and paste this address into the "Optional Image URL" box at the bottom of your post here on YT. This will allow you to post 1 picture per post. To post multiple pictures you need to write HTML and that is a little more complicated.
Al F
04-22-2005 19:16:53
 Re: Air intake question Ford 801 diesel in reply to john in la, 04-22-2005 18:16:56
third party image
The part I am talking about is at the top of the pipe I have circled. There is a nut on bolt that goes down into pipe. It is all rusted. The nut and bolt turn together. See photo
Thanks
john in la
04-23-2005 03:33:46
 Re: Air intake question Ford 801 diesel in reply to Al F, 04-22-2005 19:16:53
That pre cleaner is in 3 pieces. A base with the bolt molded into it; The clear cup; And the gray metal top.
I believe the base is pressed into the pipe but will be a bear to get it off because of years of rust and metal bonding.
While I am not there and can not look it over well I feel your only out is to go to Ford and get a whole new pre cleaner. Take the pipe and pre cleaner off the tractor and do what ever it takes to bend; break; twist; ect to get the pre cleaner off while saving the pipe.
Your oil bath filter is in that blue tray at the other end of the pipe. Take that blue tray off; clean; and refill to the line with engine oil.
Unless you keep this thing inside all the time get you a rain cap for that exhaust pipe also.
larry loy
04-22-2005 21:10:14
al..you have a correct filter for your tractor.. parts #B9nn-9A660A..I bought one awhile back for less than $25 for NH..new top..bowel..base..nut and stud..old one has a base that I think was pressed in tube...new comes with a base that slips over up tube with a clamp..very good unit..
awhtx
04-22-2005 20:19:50
It looks like someone modified your intake system.There should be some plumbing running from the red box below the intake manifold to the back side of the louvered panel just above your battery. This would be the system that john in la posted (the upper system of the two). I would remove that vertical pipe and see if you can see another nut on the bottom side of the one that just spins. You may have to hacksaw that pipe in two just below that pre-filter on the top of the pipe in order to get a hold on the bolt spins.
RickB
04-23-2005 04:07:36
 Re: Air intake question Ford 801 diesel in reply to awhtx, 04-22-2005 20:19:50
Ha has the optional pre-cleaner. Not a modification.
