Still on the learning curve with my Jubilee. Just had the starter rebuilt to replace the brushes, and in removing it found the Bendix pretty worn out, so it was a good time to replace that as well. Starts quickly, now.On the subject question, my PTO engagement lever is pretty stiff trying to get it either in or out of gear. It seems to work fine, but takes a deliberate act to get it engaged, unlike the quick flick I was used to on the Farmall. Is this normal or indicate a problem? Secondly, the 3-pt seems to work fine when selected for position control, although it slowly drifts down with a finish mower attached and bumps itself back up if the engine is running. When I select draft control, it just comes down. Is that normal? I also have an auxiliary hydraulic control working a front-mounted cylinder that operates smoothly and holds a mounted blade up in position with no drifting down. Thanks for the help. This has been a great group to get information from. =Vic= Bear Gap, PA
