Order Ford 2000 Parts Online
Ford 2000 Parts
Bennett F
04-26-2005 15:44:26
I have a Ford 2000, 3 cylinder, gas engine, s/n C16042? which, I believe dates it as a 1967 or late 1966. I need to get an oil filter for it. I"ve been told that it should take a filter and gasket that would fit in the canister, but when I look at filters of that type (on-line) they usually indicate that they are for 1965 and earlier. I have a picture of the tractor that shows the left side of the engine and the oil filter housing is visible. I don"t know how to include it here, but I can forward it to anyone who can help.
Thanks
Charles (in GA)
04-26-2005 19:39:09
 Re: Ford 2000 Parts in reply to Bennett F, 04-26-2005 15:44:26
I have a 1967 2000 that was equipped with the cannister filter. Ford switched to spin-ons later, possibly around '70.
Go to the New Holland dealer and get a conversion kit for it and get rid of the cannister. I installed an aftermarket conversion kit which works the same.
Once converted it uses a standard spin-on Ford filter, Fram PH8A, Motocraft FL1A, etc.
If you are insistent on the cannister filter, you need a Wix 51279 which is for 1965 up to October 1969 model 2000's. After 10/1969 the filter number is 51452 which is a spin on filter.
Charles
Bennett F
04-27-2005 13:36:42
 Re: Ford 2000 Parts in reply to Charles (in GA), 04-26-2005 19:39:09
Thank you. I have a few questions that you may be able to answer. While I have not ruled out converting to a spin on filter I would like to pursue a the cannister filter a lottle more. What is a Wix 51279? I understand that it is a filter element, but who makes it and where would I find it? The web site (under Ford Tractor Parts, Oil Filters) lists "Oil Filter Cartridge Type w Gasket for Models 2000... with 2 Qt cartridge filter". Is the Wix 51279 a 2 quart element? The only other cartridge type listed here is for tractors before 1965. It also lists spin on types and has a conversion kit. The other response to my original message last night suggested that NAPA would have the filter. Would they know what a Wix 51279 is?
Thanks
old
04-26-2005 18:36:53
NAPA should have the filters for it.
Bennett F
04-27-2005 13:19:05
 Re: Ford 2000 Parts in reply to old, 04-26-2005 18:36:53
Thank you.
