Proofmeter again
Bernie in MA
05-04-2005 18:38:23
I crimped the female end of the proofmeter shaft the other day and it worked good for about an hour, then quit. Took the cable out and it was spinning in the socket (female end) again. I found a drill that fit in the hole, miked it, miked the cable, and found the shaft was .030 smaller than the hole. I made a 1/8x1"x.024 shim, crimped it lengthways and put it in the hole oposite the slot the cable tab goes into. It was a press fit. The end of the cable drive comes out of the cable so I was able to lightly tap it in on the bench. I ran the tractor for 3 hours afterward with no trouble so I guess I've cured the problem. Just thought it might help somebody else.
