Can't get timing to meet specs
bigblue
05-05-2005 19:24:50
I have a 4000SU 3 cyl. and cannot move the distributor enough to get the 4 degree BTDC mark to line up with timing light. The vacuum advance hits carb. before I can get even close to 0 let alone 4. Any ideas out there?
stimw
05-06-2005 05:24:34
 Re: Can't get timing to meet specs in reply to bigblue, 05-05-2005 19:24:50
Move the wires one hole around the cap and then the distributor back, that should get you there.
txgrn
05-06-2005 06:11:09
 Re: Can't get timing to meet specs in reply to stimw, 05-06-2005 05:24:34
Now that'll work. Great idea. Course #1 should be marked on the cap.
Mark
txgrn
05-05-2005 20:08:28
Is the cam interface toothed or a slot. If toothed, back it up (move it forward)a tooth.
Mark
