power steering cylinder seal
B. Jones
05-13-2005 16:53:55
I have a 1959 971 Diesel with factory power steering. Does anyone know the part number for the seal that fits on the steering cylinder? The 971 only has 1 cylinder and is on the right side of the tractor? Is the seal hard to install? The cylinder shaft looks fine it is just dripping some oil. Also how do you get this seal out?
Joe(TX)
05-17-2005 05:34:12
 Re: power steering cylinder seal in reply to B. Jones, 05-13-2005 16:53:55
The seal for the 971 is not that expensive. The only part available is the rod seal. The row crops used a differant cylinder than the other tractors and I have not found an aftermarket one. The seal is a little dificult to dig out. There is a snap ring, washer and the seal (packing). The rest of the cylinder is welded and cannot be taken apart.
MarkB_MI
05-13-2005 18:54:31
I don't know the part number, but I'm pretty sure you can still get the repair kit from New Holland.
It's not difficult to change; you'll need snap ring pliers. But don't bother changing the seal if the cylinder shaft is scored; it will just start leaking again.
