need help with power steering
bill frederick
05-26-2005 06:07:38
Could anybody please help me. I have a ford 4000 with power steering and I cannot get it to work. There is a bleeder valve or air cap behind the control valve assembly where the power steering lines go into that it just pumps oil out of. I have no power steering.
Tony Jacobs
05-28-2005 20:38:28
 Re: need help with power steering in reply to bill frederick, 05-26-2005 06:07:38
Hi Bill, Get your service manual out to see the break down of the steering box , upper and lower seals and o rings should be replaced that are just above and below the control valve . Thanks Tony Jacobs
RoNofohio
05-26-2005 12:39:03
I had good power steering until I changed the fluid and then I lost it. I found that the GL1 oil that I used was too thick. So I changed to 134 and now it works fine. Don't know if this might be your problem, but if you haven't already changed the fluid, it couldn't hurt. Not sure if you have a filter or not. I have a 961 and it has a filter which I also changed....Ron
