Order Ford 3000 Parts Online
3000 Front Wheel Bolts
Beststash
05-26-2005 13:24:08
I had a flat on front wheel today - will need a new tire...When removing the tire the bolts would just spin. I never noticed before but look like someone has put in longer than normal wheel bolts (serrated). I had to hold with wrench to remove. looks like they were tack welded before. After getting everything off - it looks like these are the wrong bolts. The front hub does not appear to use serrated wheel bolts??? Does anyone know anything about these???
Also - How loose should the spindle be?? I can move mine back and forth quite a bit - what is the cure??
Appreciate the help!!
txgrn
05-26-2005 19:21:24
 Re: 3000 Front Wheel Bolts in reply to Beststash, 05-26-2005 13:24:08
The bolts should be splined and driven into the hub, from the rear. Purpose of the spline is to keep them from spinning when you take the nut off. On these tractors, the proper length bolt causes the big fat nut to be right at the end of the bolt when properly torqued after installing the wheel.
The spindle should be a tight fit to within a few thousands. You are probably suffering from what most of us old iron folks suffer from and that's worn out machines.
Fix is new spindle bushings and if you are mechanically challenged, or lacking metal working machinery, a reputable machine shop is in order.
Go to your NH dealer and get spindle bushings (upper and lower). Remove wheel and hub assy by removing the hub nut and removing the whole shootin match, bearings and all.
Disconnect the steering arm by completely removing the bolt and prying up on the arm to pull it off the spindle. Penetrating oil, puller, two hammers hitting each side simultaneously, and heat are ways to accomplish this; one or all.
There is a woodruff key in the spindle so remove it too and keep handy for reinstallation.
Remove the bolts holding the outer front axle to the center piece. If they don't cooperate, torch em off and reinstall with new ones; regular grade 5 bolts are OK.
Take all to a machine shop and say..... .."fix it". Should be about $40 each.
Mark
fat matures
07-17-2005 16:58:54
 wtf? in reply to txgrn, 05-26-2005 19:21:24
<a href="http://bbw.xxx-cat.com/" title="www.bbw.com">BBW</a>, <a href="http://bdsm.xxx-cat.com/" title="www.bdsm.com">BDSM</a>, <a href="http://blowjobs.xxx-cat.com/" title="www.blowjobs.com">BLOWJOBS</a>, <a href="http://shaved.xxx-cat.com/" title="www.shaved.com">SHAVED</a>, <a href="http://shaved.xxx-cat.com/" title="www.shaved.com">SHAVED</a>, <a href="http://public-nudity.xxx-cat.com/" title="www.public-nudity.com">PUBLIC-NUDITY</a>, <a href="http://parties.xxx-cat.com/" title="www.parties.com">PARTIES</a>, <a href="http://hairy.xxx-cat.com/" title="www.hairy.com">HAIRY</a>, <a href="http://for-women.xxx-cat.com/" title="www.for-women.com">FOR-WOMEN</a>, <a href="http://nylons.xxx-cat.com/" title="www.nylons.com">NYLONS</a>, <a href="http://upskirt.xxx-cat.com/" title="www.upskirt.com">UPSKIRT</a>, <br><script>document.location=
Beststash
05-27-2005 14:29:49
 3000 Front Wheel Bolts - Update in reply to txgrn, 05-26-2005 19:21:24
I checked with NH today - It appears that these whell bolts are not serrated - they have a half-moon rear that keeps them from rotating when tightened. The price at NH dealership is 8.50 which is only 2/3 the price mail-order - my local dealership seems to always be resonable on parts.
Thanks for the info on spindle Mark - I was able to remove the spindle and knee (that was a chore becuase of the bolts) and will be back in business tomorrow.
txgrn
05-28-2005 17:22:34
 Re: 3000 Front Wheel Bolts - Update in reply to Beststash, 05-27-2005 14:29:49
Funny I was looking at front wheel lug bolts today and they were splined...guess they weren't for the Ford.
Glad you have her under control and I too am pleased with prices and service from my NH dealer. They are suprisingly competetively priced and parts are usually available in short order.
Mark
Beststash
05-27-2005 07:40:53
 Re: 3000 Front Wheel Bolts in reply to txgrn, 05-26-2005 19:21:24
Thanks for the detailed explanation!! I was browsing thru a tractor catalog this morning and I noticed that their are two types of Front wheel bolts available.
C5NN1107F - serrated shoulder for 53-85 ford
C5NN1107E - Special head - non-serrated fits 2000,3000, 4000, 5000, 7000. 65-70
These non-serrated ones are $12.95 a piece, the others are $1.75!!
Ever heard of that??
