Order Ford 3000 Parts Online
charging system ford 3000 diesel?????
aaron p
06-18-2005 15:25:14
Is the voltage stabilizer a must for the system to charge, or just there for the gauges, and is there a way i can check to see if the generator regulator is working?
Also, do I need to polarize the regulator?
Michael Sutton
06-19-2005 16:39:50
 Re: charging system ford 3000 diesel????? in reply to aaron p, 06-18-2005 15:25:14
aaron p, Glad you solved your problem so quickly. Please respond and tell us what your problem was and what you did to solve it so it will be in the archives for anyone with future problems like it. I also had a problem with my 3000 Diesel not charging. My auto electric man said my generator was shot and I purchased a new one along with a new regulator. I polerized it and still had the problem. After weeks of pulling my hair out going through the whole wiring harness rechecking all of the connections retesting everything I finely came to the conclusion the voltage regulator I replaced had to be bad, After getting another one everything worked fine. Sometimes the smallest little thing can cause us to go nuts trying to troubleshoot so If you would let us know what you found and maybe help the next guy save some aggrevation. Thanks. Mike
Aaron p
06-19-2005 17:16:24
 Re: charging system ford 3000 diesel????? in reply to Michael Sutton, 06-19-2005 16:39:50
I also went through all the aggrevation. I replaced the regulator, generator and finally just went through the harness which was shot in the first place. I guess I worked backwards on this one. I did find the archives very helpful with testing the generator, which is working fine. Sometimes its the simplest things that we put off checking, that causes us the greatest expense in the long run.
Aaron
aaron p
06-18-2005 15:59:45
No need to respond to this, i have figured out what the problem was.
Thanks to all who may try to help.
Aaron
