Order Ford 971 Parts Online
971-d return line
B. jones
06-18-2005 19:06:59
Today I took off the return line from the injection pump to the fuel tank. I think the stand pipe in the tank is broken off as fuel came out quickly. I have tightened the fittings under the valve cover and I am getting very little diesel in the oil but I do need to do more testing. Can you buy the fitting with the stand pipe on it?
Hurley J. D.
06-18-2005 20:28:34
 Re: 971-d return line in reply to B. jones, 06-18-2005 19:06:59
I had the same problem with the fuel return on my 4000. I removed the fitting from the tank and installed the stand pipe with some JB weld. Just be careful when doing it and not plug the hole for the injector return line. A person might get some of the solder flux with the solder in it. Wipe the solder on the bottom of the stand pipe and heat the whole fitting until the solder melts. If the JB weld does not hold then that will be my next attempt.
Larry NCKS
06-18-2005 19:51:39
My sources say that the standpipe is no longer available through NH. I doubt if aftermarket would have anything like that either.
