Return Line message for Kelly Jewell
B. Jones
07-02-2005 11:27:43
I sent you an E-Mail message about 2 weeks ago but I'm guessing you never got it. Do you sell Ford Tractor parts such as the 311412 return line or do I need to go to my local dealer about 65 miles away? I also need a few power steering seals for my 971-D. Thanks.
Kelly Jewell (KY)
07-04-2005 12:09:38
 Re: Return Line message for Kelly Jewell in reply to B. Jones, 07-02-2005 11:27:43
Mr. Jones, I do not have these is stock, but can get. The 311412 line is $88.00, the rod end seal kit is 39.50, and the spool seal kit is 40.92. The leakback line only takes washers on top, but I've always installed top and bottom, they are $1.84 each...thanks, Kelly.
B. Jones
07-03-2005 19:10:03
I think I need both the control valve seals and the cylinder end seal. I bought 2 of the copper ?? seals for the return line( under the valve cover) but would I need 6 more or just 2 more?? While your looking, I also need the trumpet gasket for my 1947 2-N and the9N7508 bushing to tighten up my clutch pedal. Thanks. B.Jones
Kelly Jewll (KY)
07-03-2005 18:53:47
B Jones, I'll check on the line tomorrow. Which seals, cylinder rod end or control valve seals? Thanks much...Kelly
