ford tractor
Andy England
07-14-2005 11:36:48
I have a 1954 ford 640 with a loader.
I was wondering what year the loader was.
It is a ford model 19-97 with a serial number 3750.
If any one can help I"d appreciate it. Thanks
Tom in WA.
07-15-2005 08:52:59
 Re: ford tractor in reply to Andy England, 07-14-2005 11:36:48
I have a 19-97 that is original on my 850 that was built in May of 1957. The serial # is 7918. Maybe that will help you date it a little closer. You can get a manual reprint from N-news for just a few dollars.
JoeB_4000
07-15-2005 07:10:46
I have a Ford 703 loader on my 1962 4000 that has the same model number (19-97). I believe that this would be the loader -- I think they were manufactured from the 1950s through 1970s.
HTH Joe
Joe(TX)
07-15-2005 04:58:21
If it is a 640 it has to be 1955 or later. The 1954 was an NAA. I can't answer the loader question.
Jim.UT
07-15-2005 09:45:09
 Re: ford tractor in reply to Joe(TX), 07-15-2005 04:58:21
You're both right....kinda. Yes the 600/800 series were introduced as 1955 models, but the first 10,000 or so were actually manufactured in late 1954, so sometimes those with early serial numbers will say it's a 1954...same way an early 8N will be called a 1947 when the owner's manual clearly states 1948. In fact, the 8 in 8N is supposed to designate 1948, the "first" year of the 8N. Actual production of the 8N started in June or July of 1948 and more than 30,000 were built in '47.
Jim.UT
07-15-2005 09:46:28
 oops in reply to Jim.UT, 07-15-2005 09:45:09
I meant to say 8N production started in June or July of 1947, not 1948.
