help with steering leak
andrea
07-20-2005 15:09:19
i have a ford 4000 1975 3cyl dsl. tractor. i am new to tractors so if i sound dumb i am. i bought it used and havent used it much yet. i was driving it and i seen power steering fluid leaking from the top of the steering column. right under the steering wheel. is there a seal there that i can replace, and if so what is it called. any help would be appreciated
hvw
07-20-2005 16:12:33
 Re: help with steering leak in reply to andrea, 07-20-2005 15:09:19
There is a seal in the bottom of the steering column and more than likely that's what is causing your problem. Any NH dealer will have the seal.
If I remember correctly you have to remove the sheet metal and then the steering column to get to it. It's a do it yourself job with regular tools. More time consuming than hard. Getting the steering wheel to come off is usually the hard part.
I've always thought that after you go to that much trouble removing stuff you should check all the bearings, seals, etc before putting it back together.
In any case it's been a long while since I replaced mine so if I'm not remembering right someone will set me straight.
