Help ID a mystery Ford!
billOH
07-24-2005 17:58:51
My neighbor recently purchased a new Ford, which we believe is a 2000 of some sort. The tractor is all blue (supposedly its original color), gas, and has a select-o-matic type tranny.
On the left side of the engine, on a plate, are the numbers: 21205
<>60624<>
On the right side, are the cast numbers: CONN60150
Any idea what this thing might be? It came with power steering, though I don't know if that's an original feature.
Russ SoCal
07-25-2005 05:46:16
 Re: Help ID a mystery Ford! in reply to billOH, 07-24-2005 17:58:51
bill,
Wanna get real confused? It's taken 40 years to decode, but the Vintage Ford Tractor Resource explains why there are more numbers than there are tractors. 2000 series are about 2/3 of the way down the page.
Russ ; ^ )
txgrn
07-25-2005 05:22:52
The first 2 is series = 2000
Then Utility (x1xx) and pto style (transmission type) and trannytype/gears (5 = SOS as I recall).
The other is serial number and it is low so I'd say you have an early '60's 4 cyl.
Mark
Roy Suomi
07-24-2005 20:42:29
3 cylinder or 4 cylinder engine?? On 3 cylinder tractor the numbers are stamped on top of the starter boss on the clutch housing. Usually starting with a "C" then numbers behind it..Both 3 or 4 cylinder tractors used a select-o-speed transmission.
