Order Ford 8N Parts Online
Ford 8N Problem
Arthur Strader
08-03-2005 08:29:04
I am having trouble on my Ford 8N.The tractor has
been running fine,have not used it in about a month.When to start it,when I hit the starter it
just clicks,thought it might be the battery,had it checked and was told it is okay.The tractor has been converted to a 12v.system,what should a
fully charged 12v.battery read in volts.All the
terminal posts and connections are clean.Could someone tell me what the problem might be.Many
thanks.
souNdguy
08-04-2005 06:15:35
 Re: Ford 8N Problem in reply to Arthur Strader, 08-03-2005 08:29:04
About 12.6v on a good battery.. shouldn't drop below about 10v when starting.
The others gave you good advice.
Sometimes the bendix stays engaged int he flywheel as well..
Soundguy
Rick H. Ga.
08-03-2005 09:06:10
Possibilities: loose/corroded electrical connections, bad battery (I have had them check out good and still be bad under a load), bad/defective solonoid coil/switch, bad starter thumb button, bad/defective starter. HTH. Rick
old
08-03-2005 09:03:08
Soliniod maybe bad or the strater. With it out of gear jump around the soliniod and see it the start will spin if it does its the soliniod if not its the starter. You also might try tapping on the soliniod some times that will get them to work again
Tim B from MA
08-03-2005 09:19:33
 Re: Ford 8N Problem in reply to old, 08-03-2005 09:03:08
You also should try banging on the starter - sometimes that helps if the bushings or bearings are half shot.
