850 governor spring
BTR TN
08-08-2005 19:24:37
I just bought a 1955 850 that runs great (low, steady idle; no misses under load; no leaks) but has a few cosmetic things to fix. I have been trying to find the spring for the governor assembly with no success. Does anyone know a source? The gauges are also history. Is there a simple way to determine if the sending unit OR the gauge (or both) are bad? Will an aftermarket gauge work or must I go with OEM (or equivalent) to get accurate readings? I appreciate any help...first time tractor owner...just need to brushhog 10-12 acres a couple of times a year. I have a 5' King Kutter from TSC.
