Order Ford 5000 Parts Online
Using newer 4wd gearbox in Ford 5000?
4wd maniac
08-14-2005 15:30:20
Hi
Im looking into changing the gearbox and front suspension on my Ford 5000, and was wondering if any of the newer ford, for example 6610 4wd, 5610 4wd etc, uses the same gearbox type of gearbox, if so are they interchangeable with the 5000?
im thinking i can use most of the drivetrain from a 4wd and build my 5000 2wd into a 4wd, but maybe im wrong?
Bern
08-14-2005 16:10:31
 Re: Using newer 4wd gearbox in Ford 5000? in reply to 4wd maniac, 08-14-2005 15:30:20
You"d have to exchange the complete rear axle housing from a donor tractor to get this done, at least if you want to make it like a 10 series, as those tractors had the transfer case attached to the bottom of the rear axle housing. Steering would likely be another issue if you had to convert it to hydrostatic steering.
Why go through all this trouble? Why not just buy a 6610 if you"ll need it for parts anyway?
