Order Ford 2000 Parts Online
2000 Industrial vs the auger
Timbow
06-29-2001 12:03:23
Can't get a Ford auger to clear the ground with my 2000 Industrial. Hydraulics seem fine. The tractor mount point seems high relative to neighbor's late model (which hike the beast right up). The geometry just seems to be a little to flat (limited pivot angle). Thoughts?
texadian
07-02-2001 07:59:13
 Re: 2000 Industrial vs the auger in reply to Timbow, 06-29-2001 12:03:23
Three point hitch should have a maximum height of 32 inches and a lower height of 8 inches at the balls, category one, per SAE specs. If hitch does not lift to approximately this height, the hitch hydraulic control valve linkage needs to be adjusted. There's a cam on the hitch rockshaft and a cam follower which moves the control valve to neutral when the preselected height has been reached. Presuming the tractor has standard tires and sits approximately level.
