where does elenco 4wd get it's power?
641er
08-29-2005 13:23:08
I have only seen pictures of Fords equiped with an Elenco 4wd kit and have been wondering where does it get it's power from? I have seen in the pictures that the differential is offset to the left as seen from the drivers seat and that a driveshaft runs under a guard near the clutch pedal. Is the Elenco kit full time 4wd or can it be disengaged? From reading past posts, I'm hoping that Tony Jacobs see this.
Feron
08-29-2005 14:18:35
 Re: where does elenco 4wd get it's power? in reply to 641er, 08-29-2005 13:23:08
The Elenco gets the power from a sprocket on the tractor drive coupler, There is a chain to the transfer case on the left of the tractor. The drive shaft runs beside the clutch pedal. The one I have is the newer Elenco they are able to be disengaged. not the older ones
641er
08-29-2005 14:24:18
 Re: where does elenco 4wd get it's power? in reply to Feron, 08-29-2005 14:18:35
Thanks for the info. I have always wondered since first seeing a picture of one. One more question, what and where is the tractor drive coupler? Inside the transmission or rear axle?
RICKWI
08-29-2005 16:06:48
 Re: where does elenco 4wd get it's power? in reply to 641er, 08-29-2005 14:24:18
The chain comes out the hole where the PTO lever/cover is located.
Feron
08-29-2005 15:19:32
Yes the coupler is inside in between the trans and the rearend
