Anchor point for bottom link
53GoldenJubilee
08-29-2005 14:06:34
Hi guys,
On my 53 jubilee there are 2 studs or bolts the anchor the bottom links for the 3pt. The left side seems to be correct with no play in the stud but my right side anchor has lots of play and rotates freely , so freely that it cant be undone but it wont pull out and I cant take the right bottom link off the anchor. How is this supposed to be setup? Can anyone give me a diagram of inside the axle housing to show how this system works? thanks a bunch.
53GoldenJubilee
08-30-2005 13:38:57
 Re: Anchor point for bottom link in reply to 53GoldenJubilee, 08-29-2005 14:06:34
Thanks for the help guys! got it fixed!
Hobo,NC
08-30-2005 04:32:54
third party image
EZ way izz to use a engine crane to remove the trumpet as a complete assy then reach in and remove the differential. The you kin git to the right pin
Charles (in GA)
08-30-2005 02:19:52
You should be leaking gear oil from around that loose stud. If not, you don't have any in the differential.
You will have to remove the axle trumphet housing to fix this problem.
Charles
WayneNC
08-29-2005 18:53:45
Jubliee, To get to the inside castle nut you have to remove right axle housing. I think there was a pic on parts & pieces to your left.
