Order Ford 4000 Parts Online
1964 Ford 4000 Fan
BDWis.
09-18-2005 17:21:52
I have a 1964 Ford 4000 Industrial with the 172 gas engine. The fan that it has is 6 bladed, 15.5" dia. Is this the correct fan. The bottom of the shroud was removed, I'm thinking to make room for this fan. The IT manual shows a picture of a 3 bladed fan. Does anyone know what is the correct type and dia.? I have a new shroud which will not fit the current fan.
Scott PA
09-18-2005 18:03:02
 Re: 1964 Ford 4000 Fan in reply to BDWis., 09-18-2005 17:21:52
A 6 blade was available, 3 blades were standard until 1971 then Ford changed water pumps and it required a different pulley, spacer and a 4 blade fan, so it depends what pump is on now, your front axle support may also be worn and the shroud can't go low enough to clear the fan.
