Order Ford 6000 Parts Online
6000 ford Nebraska test.
B. Jones
10-04-2005 19:00:30
Why did Ford test the 6000 in March of 1961 at 2400 rpm. Another test was done in June of 1963 at 2230 rpm. The final test was done in March of 1965 at 2430 rpm. Does anyone know why ford kept changing the rpm and hence the horsepower of this tractor? Just curious if anyone knew the reason.
B. Jones
10-05-2005 10:38:30
 Re: 6000 ford Nebraska test. in reply to B. Jones, 10-04-2005 19:00:30
Each time they tested both gas and diesel for a total of 6 different tests. thanks.
Rlach
10-05-2005 17:07:51
 Re: 6000 ford Nebraska test. in reply to B. Jones, 10-05-2005 10:38:30
Test 783 : 6000-Diesel
Engine rated at 2400 rpm
540 pto @ 2227 crankshaft rpm
Test 784 : 6000-gas
1000 pto @ 2227 crankshaft rpm
Test 842 : 6000-gas
Engine rated at 2300 rpm
Test 843 : 6000-Diesel
Engine rated at 2230 rpm
1000 pto @ 1731 crankshaft rpm
Test 877 : Commander 6000-gas
Engine rated at 2430 rpm
Test 878 : Commander 6000-Diesel
1000 pto @ 2228 crankshaft rpm
They finally rated the engine @ 2430 rpm or exactly 200 rpm above the engine rpm required to obtain 540 or 1000 rpm in normal operation mode!!! It looks like the 2000/2200rpm for other models. Is there any logic for this choice ? not sure. Rlach
Gaspump
10-05-2005 11:13:31
I sure don't know but only could surmise that they were looking to max something such as HP, fuel economy etc but gas and diesels would have differing power curves so while one test may help a diesel it may be detrimental to a gas. I would be interested to know the outcome.
Gaspump
10-05-2005 08:04:03
Gas, Diesel, Updated engine?
john_bud
10-05-2005 19:26:32
 Re: 6000 ford Nebraska test. in reply to Gaspump, 10-05-2005 08:04:03
Those RPM's sound like one they were going between a manual transmission and an SOS transmission. Don't know if it relates perfectly or not, but the engines in the 4 cyl 4000 series were rated at 2200 rpm for 4 speed and 2400 rpm for SOS. Could that be part of the issue?
jb
Jeff Wenner
10-06-2005 09:03:01
 Re: 6000 ford Nebraska test. in reply to john_bud, 10-05-2005 19:26:32
Did they make a 6000 with a standard tranny?
730 virgil
10-05-2005 19:22:17
what is horsepower of 6000 gas and diesel ? did commander have more horsepower ? what are major differances between the 2 ?
Ken in Arkansas
10-06-2005 12:42:27
 Re: 6000 ford Nebraska test. in reply to 730 virgil, 10-05-2005 19:22:17
I think all 6000's were SOS transmission.
