ford colors???
bovie13
10-05-2005 19:44:47
Recently purchased a 195? 800 series, needs some work but runs well. What were the original colors?
Dan
10-07-2005 06:49:12
 Re: ford colors??? in reply to bovie13, 10-05-2005 19:44:47
third party image
The same colors as my NAA has. This is pretty close to the original shades.
Dan
Danny IN
10-06-2005 18:14:32
Go to your Ford New Holland dealer and get their paint.
Red (39/62)
Grey (39/62)
Those are the colors that I used on my 960 and it looks great
Jen
10-06-2005 16:26:12
Tractors are not supposed to BLUE!!!!! !! any other color is fine.... just not blue.....
Jim.UT
10-06-2005 12:08:17
Colors? Like old said: red and gray. There can be some variations of shades the you'll see on tractors. Starting with the x01 series, the Ford red started leaning toward orange. Lots of older tractors got repainted the orangy color because that's what the dealer started to stock in his parts department. My 850 sports a nice shade of red underneath the peeling orangy repaint.
Here's a pic of someone else's tractor showing the colors I like. This is NOT my tractor.
third party image
Jeff Wenner
10-06-2005 09:00:33
Should be a 1" high casting code on the front of the rear axle, left side, I think. Mine says D55, D, the forth letter means April, 55 means 1955.
Jim.UT
10-06-2005 12:01:29
 Re: ford colors??? in reply to Jeff Wenner, 10-06-2005 09:00:33
Almost, Jeff. The D is April as you said. The last 5 is 1955, but the middle 5 means the 5th of the month. So your date code is April 5, 1955. An axle cast the next day would have a code of D65 and an axle cast on the last day of the month would be D305.
Jeff Wenner
10-07-2005 04:27:48
 Re: ford colors??? in reply to Jim.UT, 10-06-2005 12:01:29
Yep, your right, sorry about that.
souNdguy
10-06-2005 05:37:46
XX0 is 55-58
800 is series number
Look for a sn lightly hand stamped on the left side above the starter. Will be a sn and a 3 digit model number.. I.e. 840 850 860.. etc, depending on trans and pto options / tractor options.
You can find year of manufacture with the sn.
Soundguy
old
10-05-2005 20:42:42
Should be red engine, tranny and rear end and gray sheet metal.
